Clear search results on page reload?
Thread begun 6/09/2010 6:18 am by fabianmacs370894 | Last modified 6/09/2010 9:33 am by fabianmacs370894 | 4170 views | 6 replies |
fabianmacs370894
I have two pages, search and results. Search works fine - problem is when I re-load the results page without any search the old search result records still displays and not ALL the records that I require.
How can I clear the old results when page is reloaded.
I have used Dataassist Search Wizard
Files are attached.
Thanks for any help in advance.
Fabian
to clear the search results every time the page is loaded, add the following code at line 1 of your page:
if(!session_id()) session_start();
if(isset(
$_SESSION["WADbSearch1_resultsallenhanced"])) unset($_SESSION["WADbSearch1_resultsallenhanced"]);
fabianmacs370894
PHP Code throwing up blank page
Jason,
Tried that code. Window is now blank. Must be an error on script?
add :
error_reporting
(E_ALL);
at line 1 to turn error reporting on
fabianmacs370894
No error displaying, just blank page.
Jason,
Still no luck and no error being generated?. Here is the files again. Maybe I have it in wrong part of code?
Thanks,
Fabian
Ok, I see the problem now, I had a typo originally;
change
if(!session_id()) session_start);
to
fabianmacs370894
Problem solved
Thanks Jason,
Final code that worked:
if (isset($_SESSION["WADbSearch1_resultsallenhanced"])) unset($_SESSION["WADbSearch1_resultsallenhanced"]);
