Image upload on web server
Thread begun 6/08/2010 9:56 am by lyle406399 | Last modified 6/14/2010 8:45 pm by larry268887 | 3424 views | 5 replies |
lyle406399
I have added the editor to content page insert and update for CMS. I have also added the image upload compontent, this works fine on my local testing server. But when it was uploaded I can no longer browse for files or upload files. The folder permissions are correct, is there an absolute path that I need to use instead? eg uploads/
Does this need to be changed in multiple places or just the PHP config file.
can you give some more specifics?
What happens when you try to browse for the folder or upload files?
Do you get an error message?
If so what is the text of the error?
can you provide a link?
lyle406399
Error Message
When I browse server I now get 500 Internal Server Error.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. This page is located in a CMS backend.
lyle406399
image upload
I have the editor responding. On the file directory on the localhost testing locally the address for the browse for image is
index.php?lang=default&kfm_caller_type=fck&type=Image
but on the actual site it comes up with
this page is then blank.
the uploads folder is in the main directory. It can't seem to find it.
login.php
larry268887
Sounds like the same problem when you use menu writer on a site sculptor site.
