Documentation on procedure to restore
Is there any docuemntation on how to save and restore images stored in the mysql, and the recovery procedure needed in Powergallery if something goes wrong and a restore is needed?
The images are actually stored in a directory on your server within your PowerGallery directory. The images directory holds a directory for each of your galleries and in each of those directories, the necessary images are stored. The name of the images are stored in the database. So to backup your gallery, you would want to export your database (the way you would normally to backup a database) and backup the images directory within your PowerGallery.
