Updating extensions
Thread begun 6/07/2010 12:21 pm by mpackard160945 | Last modified 6/07/2010 6:14 pm by Eric Mittman | 1448 views | 1 replies |
mpackard160945
Updating extensions
How do you update an extension?
I have 8 webassist extensions installed and now that I'm updating CS4 to CS5 I need to update them all.
Do I have to manually download, delete existing, and re-install all from scratch?
That's a lot of work.
Isn't there a better way so that when an update comes in I can click one or two buttons and have it install, replacing the older one?
Thanks for helping
Mike
You will need to completely uninstall the previous version of the extension before you install the newest version. When you are installing the new extension you should select 'yes to all' if you get prompted to overwrite existing files.
