CMS2 cannot connect to database
Thread begun 6/07/2010 7:52 am by kbettenc296716 | Last modified 6/08/2010 5:42 pm by Eric Mittman | 2613 views | 3 replies |
kbettenc296716
I am installing PowerCMS 2 and MySQL database on an Apache server for the first time and the nomenclature has me beat. Or, perhaps it is just this ISP. I named the database "cmsDB" and the user "admin". The Control Panel attached a prefix to both clientname_cmsDB and clientname_admin. I try to use those in the install and it says it cannot connect. See attachment for all files.
It definitely looks as though you are specifying the name of your db and username correctly. I'm not sure why you would get this error if the db exists with that name. Something that you may want to try is to create a new db and make sure to use only lowercase characters. Then create a new user for the db and do the same for the username, use only lowercase letters.
This is about the only thing that I could think of that would cause you to not have access. Let us know if you continue to have problems with this and we will take look with you for some of the settings and try to help determine what the problem is.
kbettenc296716
Victory
That must have been it, also I tweaked the user privileges. Thanks.
Glad to hear that. Let us know if you have any other questions.
