Fatal error: session_start()
Thread begun 6/07/2010 3:58 am by joe159765 | Last modified 5/12/2011 8:44 am by kdavid379212 | 2273 views | 4 replies |
joe159765
I have used universal email on other sites with no problems. This is new to me. The php.ini settings are the same as always. But I am receiving this error
Fatal error: session_start() [<a href='plugins/function.session-start'>function.session-start</a>]: Failed to initialize storage module: user (path: )
Is there something I should be looking at or should I share my code with you? Thanks.
the error indicates a problem with the session.save_path in the php.ini file.
make sure that the session.save_path points to a location that actually exists on the server.
joe159765
So I think what was actually happening is I was including ssi.php from Simple Machines Forums and something in there was messing around with the sessions. So I had to do that form on it's own page to work around this. Just in case anyone else comes across something like this.
Thanks.
ok, glad to hear you have it working.
kdavid379212
Thank you, Joe! I was pulling my hair out with this one and the SSI.php was what was messing everything up.
