HTML Editor and Dw CS5
Thread begun 6/06/2010 12:26 pm by g292818 | Last modified 6/07/2010 1:41 pm by Jason Byrnes | 4735 views | 6 replies |
g292818
I have just installed HTML Editor on Dw CS5. It installed fine (I had expected that the installation would fail -- well because it is not listed on the webassist site as CS5 compatible ..yet.)
Does that mean it will work it installed fine..?
Please respond.
It mayor may not work. We have not yet tested HTML editor i n DWCS5 to ensure compatibility.
g292818
Ok
Okay then.. thanks.
Is it possible to give an estimate or indication on when all extensions will be CS5 compatitble?
MikeH
Hi
I have noticed that you have now updated this to CS5 can you confirm if the fix for the fix was made to the file manager to get an image remotly was added?
Mike
version 2.0.2 was released only to address Dreamweaver CS5 compatibility, no bugs where fixed in this release.
MikeH
Hi Jason
Did that really make sense when HTML editor is used in so many of your solutions?
Surely simple bug fixes like the on e I mentioned would have been easy to implement rather than release an update with easy to fix bugs still there?
Mike
Right now we are concentrating on DWCS5 compatibility, once done with CS5 compatibility updates, we will be addressing bug fixes.
