New DataAssist takes 15 minutes to install!
Thread begun 5/28/2009 5:52 pm by Peterson Design Studio - jefferis | Last modified 6/11/2009 1:34 pm by Travis250923 | 7342 views | 10 replies |
Today's release of DataAssist 2.0.5 on Mac Intel 10.5.7 took 15 minutes to install...
I-CRE8Beta Tester
not that's its any consolation but mine was almost instantaneous and along with the new site import version installed tis morning
Originally Said By: I-CRE8
Hi Dave, I see by your byline, you now have an official relationship with WA? :-) Congrats. The new Site import installed quickly for me, but somehow the delay on DA was so long I thought the program had stalled and force quit EM after 20 minutes first go round. Then I rebooted and tried again, and just let it run. I was just about to quit it again after 15 minutes when it finally came to the second screen asking if I wanted to replace exisiting components. I said yes to all, and it finished quickly. I haven't actually tried using it yet! That will be later today.
Make sure to completely uninstall the version you have installed before installing the new one. You will see it is actually uninstalling the previous version that takes so much time. Installation is always quick for just about every extension. The extension manager is horribly slow when uninstalling.
Personally, I often will rename my configuration folder to reinstall every extension I have rather than use extension manager to uninstall one. For me it is quicker since I store all my extension files in one place and can quickly install them.
Uninstall can take 15 minutes for me too with extensions that include a lot of files. I have noticed clearing my trash will make it much faster, and the experience on mac is pretty fast in general.
But on my windows xp machine I can install probably 30 extensions in the time it takes to uninstall one if I just rename the configuration folder. Of course I lose any custom themes and layouts I had stored, so there is the pain of having to re-serialize and re-import any defined layouts which may make using the extension manager more worthwhile for some.
I don't think there is anything WebAssist can do about it though. It appears to be a general problem with extension manager uninstalling extensions with large numbers of files. We could only solve the problem by breaking up our extensions into more extensions or by simplifying the extensions themselves, and neither of these seem very logical in response to this issue.
I guess we could create our own installer and uninstaller to address the problem as well... with the winfilecache issue of late that sounds more and more promising, but for now we are sticking with the extension manager and hoping adobe will address the efficiency problems in a future update.
I agree it isn't your problem. EM has been a beast for years. However, I have too many extensions (PVII and yours and ADDT) to reinstall the whole lot. It takes me 1/2 a day. I tried uninstall after the first failure, but EM would not respond at all, or if it was, I could not tell it was trying to uninstall... So I just reinstalled...
If you don't completely uninstall it can cause the winfilecache problem, so I'd recommend always uninstalling.
It is true that it can appear to hang during this process. No more or less than it appears to hang in the reinstall process however, so I would still always recommend uninstalling completely. Do it before lunch and walk away so it won't bother you how long it takes or how it appears to have stopped responding.
Nigel
New DataAssist 2.0.5 Crashing DW CS4
I installed the updated DA today. I opened a page with DA server behaviors but when I double clicked to open a server behavior (Manage Relational Tables) in the SB panel, I got the crash dialog "DW CS4 has encountered an error..." or such. I tried again and this time used Insert > DA Wizard and got a JavaScript error, no crash.
"While executing onLoad in WA_AppBuilder.htm, the following JavaScript error(s) occurred:
In file WA_AppBuilder: Initialize UI is not defined.
Has anyone else had problems?
Try deleting your winfilecache
Nigel
Problem solved. Thanks Ray.
That is the problem when you don't completely uninstall before installing a new version with extension manager.
