All DD Menus select first line option including Design
Thread begun 6/05/2010 8:54 pm by connie386947 | Last modified 6/07/2010 1:56 pm by Eric Mittman | 1343 views | 1 replies |
connie386947
I just installed CSS Sculptor with Dreamweaver CS4 and am trying to create my first site in CSS.
I chose my 2colfixedheaderfooter type and was puzzled when Cabo Sunset kept coming up whenever I chose the Default design. Finally gave up and accepted Cabo and began customizing.
As I got into setting the fonts, I discovered to my frustration that no matter what I chose in a Dropdown menu, the first item on the list always came up. eg., if I selected Trebuchet font, the Arial line came up as the selection. If I wanted 10 points, 1 point came up. I had to choose every item TWICE to get the item I wanted.
After some frustrating false starts, I finally saved the design as a present under its own name (about 5th on the design list). Now, though, when I try to access the Design to edit it, all that comes up is the first design on the list -- CABO SUNSET.
I searched this forum and found a similar problem for someone using CS3 -- replacing a certain .js file in the ...Configuration/Commands folder.
I followed those instructions, but it didn't solve the problem. I am still unable to access ANYTHING but Cabo Sunset. I'm about ready to go into Dreamweaver application data folder and delete all the presets alphabetically until I get mine up to the top!
Can someone please help me? I've been trying and failing to create CSS websites and Sculptor finally gives me hope that I can succeed. But I've got to get the darned thing to work right!
Thanks for anything you can do to help me get this fixed!
I have opened a ticket for you on this issue so that it can be looked into further. To check the status of your ticket login and visit your support history.
