limiting output
Thread begun 6/05/2010 6:33 am by web364946 | Last modified 8/24/2010 9:11 am by Jason Byrnes | 8178 views | 23 replies |
web364946
limiting output
I am trying to create a page, which the used will be able to update herself using Power CMS.
On the index page, I only want to display part of the content, let´s say the first 200 characters, and then to read the remaining content, the user will have to click on "more".
I found a previous entry in this forum, concerning the same issue - your suggestion was to use the following entry:
<?php echo substr(WA_getCMSContent($database_localhost, $localhost,"Home Page", "Welcome"), 0, 150)."..."; ?>
Using my own settings, this should correspond to:
<?php include('cms102/WA_CMS/addtosite.php'); echo substr(WA_getCMSContent($database_localhost, $localhost, 'index.php' , 'content') "), 0, 150)."...";?>
However, when using this, I only get either a blank page, i.e. no content showing at all (not even background color or any design details) or error 500.
What am I doing wrong and how can I get the page to work?
anonymous
I would actually do it like this:
First add this function at the top of your page:
// CUTTEXT
function cutText($string$length) {
if(
$length<strlen($string)){
while (
$string{$length} != " ") {
$length--;
return
substr($string0$length);
}else return
$string;
Then, where your content is:
$content = (WA_getCMSContent($database_localhost$localhost'index.php' ,  'content');
$content strip_tags($content'<p><a>');
$content cutText($content150);
echo
$content;
Now, I know this looks like a bit more code, but it will be better in the end because you will use the Strip Tags function to strip out any html tags - such as image tags or other tags that will actually eat up character length. The other problem if you don't strip tags is what happens when your substring ends in the middle of an open html tag such as an image.
In the example I provided, you'll notice after the strip tags command in the parenthesis, I have "<p><a>" as the second attribute. This means that all html tags EXCEPT the p and a tags will get stripped. I usually do this to leave the paragraphs and links in tact while getting rid of images and all other stuff for preview purposes.
After I strip the tags, I then call the custom Cut Text function to trim it down to what I want.
Regards,
Brian
web364946
Thanks for your reply! I have tried to do as suggested, but keep getting either a blank page or error 500. What am I doing wrong? I have literally copied the code you sent and pasted it in at the correct (I hope) place - still not working!
I'll be happy to send you the ftp/login details if you want to take a look.
Thanks again.
web364946
I am still having problems with this- any suggestions?
add the following to line 1 to turn error reporting on:
error_reporting
(E_ALL);
we will need to know the error that is occurring to have an idea about the cause.
web364946
I have added the code as you suggested.
The page in question can be found on the following address (or should be found at least; at the moment I am just getting error 500)
index3.php
web364946
Any news on this?
It's impossible to tell what may be wrong without knowing the error message.
Perhaps if you could send a copy of the index3.php page, i could spot something, other than that, you should check with the host to see if they can look into the server error logs to find the error message.
web364946
Here is the code:
error_reporting(E_ALL);
// CUTTEXT
function cutText($string, $length) {
if($length<strlen($string)){
while ($string{$length} != " ") {
$length--;
return substr($string, 0, $length);
}else return $string;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html><!-- InstanceBegin template="/Templates/forlag404_3.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!-- InstanceBeginEditable name="doctitle" -->
<title>Förlag 404</title>
<!-- InstanceEndEditable -->
<link href="css/css.css" rel="stylesheet" type="text/css">
<!-- InstanceBeginEditable name="head" --><!-- InstanceEndEditable -->
</head>
<body bgcolor="#000000">
<p>&nbsp;</p>
<table width="900" border="0" align="center" cellpadding="0" cellspacing="0" bgcolor="#FFFFFF">
<tr>
<th width="36" rowspan="11" scope="col">&nbsp;</th>
<th width="160" height="20" scope="col">&nbsp;</th>
<th width="20" height="20" scope="col">&nbsp;</th>
<th width="700" height="20" scope="col">&nbsp;</th>
</tr>
<tr>
<td colspan="3"><img src="images/banner.jpg" alt="" width="860" height="100"></td>
<td width="20">&nbsp;</td>
</tr>
<tr>
<td colspan="3">&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td colspan="3"><table width="850" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td height="1" bgcolor="#D31424" scope="col"></td>
</tr>
</table></td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
</tr>
<tr>
<td width="160" height="50">&nbsp;</td>
<td width="700">&nbsp;</td>
</tr>
<tr>
<td width="160" valign="top"><!-- #BeginLibraryItem "/Library/nav.lbi" --><table width="160" border="0" cellpadding="0" cellspacing="0" id="nav">
<tr>
<th scope="col"><img src="images/lankar.jpg" alt="" width="157" height="300" border="0" usemap="#Map">
<map name="Map">
<area shape="rect" coords="6,5,152,37" href="index.php" target="_parent" alt="Startsidan">
<area shape="rect" coords="6,40,153,70" href="pages/bocker.php" target="_parent" alt="Böcker"><area shape="rect" coords="3,144,148,182" href="pages/kompisar.php" target="_parent" alt="Våra kompisar">
<area shape="rect" coords="3,73,153,104" href="pages/om_forlag404.php" target="_parent" alt="Om Förlag404">
<area shape="rect" coords="3,107,152,140" href="pages/kontakt.php" target="_parent" alt="Kontakta Förlag 404">
<area shape="rect" coords="3,185,146,213" href="pages/bestall.php" target="_parent" alt="Beställa böcker">
<area shape="rect" coords="6,258,108,304" href="http://www.facebook.com/pages/Offerdal-Sweden/Forlag-404/123065114393977?ref=ts&__a=7&v=wall" target="_blank">
</map></th>
</tr>
</table><!-- #EndLibraryItem --></td>
<td width="700" valign="top"><table width="700" border="0" cellspacing="0" cellpadding="0">
<tr>
<td width="480" valign="top" scope="col"><div align="left"><!-- InstanceBeginEditable name="content" -->
<table width="480" border="0" cellspacing="0" cellpadding="0">
<tr>
<th height="30" scope="col"><div align="left"><img src="images/redaktoren.gif" width="163" height="30" border="0"></div></th>
</tr>
<tr>
<td height="30"><div align="left"></div></td>
</tr>
<tr>
<td><div align="left"><?php
$content = (WA_getCMSContent($database_localhost, $localhost, 'index3.php' , 'content');
$content = strip_tags($content, '<p><a>');
$content = cutText($content, 150);
echo $content;
?> </div></td>
</tr>
</table>
<!-- InstanceEndEditable --></div></td>
<th width="20" scope="col"><div align="left"></div></th>
<td width="200" valign="top" scope="col"><table width="200" border="0" cellpadding="0" cellspacing="0" id="column">
<tr>
<td valign="top" scope="col"><div align="left"><!-- InstanceBeginEditable name="column" -->
<table width="200" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td height="30" scope="col"><div align="left"><img src="images/aktuellt.jpg" alt="Aktuellt" width="160" height="30" border="0"></div></td>
</tr>
<tr>
</tr>
<tr>
<table width="200" border="0" cellspacing="0" cellpadding="0">
<tr>
<td scope="col"><div style="height: 300px; width: 200px; overflow: auto;"><table border="0" align="left" cellpadding="0" cellspacing="0" bgcolor="#ffffff" id="updates" >
<tr>
<td height="30" valign="top" scope="col"><div align="left"></div> <p>&nbsp;</p>
<div align="right"></div></td>
</tr>
</table>
</div></td>
</tr>
</table>
</div></td>
</tr>
</table>
</tr>
</table></td>
</tr>
</table></td>
</tr>
<tr>
<td width="160">&nbsp;</td>
</tr>
<tr>
</tr>
<tr>
<td colspan="4"><table width="850" border="0" align="center" cellpadding="0" cellspacing="0" bgcolor="#c01921">
<tr>
<th height="1" scope="col"></th>
</tr>
</table></td>
</tr>
<tr>
<td colspan="4"><table width="900" border="0" align="right" cellpadding="0" cellspacing="0">
<tr valign="bottom">
<td width="100" scope="col">&nbsp;</td>
<td scope="col"><div align="center"><a href="http://www.getawebsite.se" target="_blank" class="owd">©Design: Offerdals Web & Development</a></div></td>
<td width="100" height="71" background="images/corner.jpg" scope="col">&nbsp;</td>
</tr>
</table></td>
</tr>
</table>
<p>&nbsp;</p>
</body>
<!-- InstanceEnd --></html>
Please dont paste the code into the message, instead compress the original php file into a zip archive and attach the zip archive to you reply.
