Related Items on Details Page
Thread begun 6/04/2010 1:16 pm by deno1965 | Last modified 6/07/2010 10:18 am by Jason Byrnes | 3031 views | 1 replies |
deno1965
Ok, I have a products table and 3 main categories for possible related items. How would I go about showing these related items if there is any (I know show region here) on the details page of the main item? I would only want to show those specific to that item. Also there could be more than 1 item in a given categorie for that initial item. The table layout is what's blowing my mind. I'm thinking two tables and a inner join of some sort. Hope this makes some sense.
Initial Item Description
The Categories if any:
Blocks(Maybe more than 1) Modules ect...
yes, you would need a second table to record the related products.
productrelations:
relationsID: primary Key
prodID: Main products ID
related prodID: ID of related products
so to relate product ID 3, 8 and 14 to product 1:
relationsID | prodID | related prodID
1 | 1 | 3
2 | 1 | 8
3 | 1 | 14
to display the product information, use a join query:
SELECT products.*
FROM products
INNER JOIN productrelations
ON products.ProductID = productrelations.prodID
WHERE productrelations.prodID = paramProdID
then create a new parameter:
Type: Number
default value: -1
RunTime Value: $_GET['<querystring name>']
change <querystring name> to the name of the querystring that is passed to the details page, for example, if the details page is called as :
productDetails?prodID=1
then the run time value is:
$_GET['prodID']
