eCart 5/confirm page fails to load payment page
Thread begun 6/04/2010 6:09 am by dave403891 | Last modified 6/09/2010 1:42 pm by Jimmy Wu | 3764 views | 7 replies |
dave403891
I've uploaded my site and all works beautifully except when I click on the checkout button on the confirm page the payment page does not open and I get this error:
The following errors have occurred.
(99) This transaction cannot be accepted.
I'm not certain of what to do. Any suggestions?
I'm using authorize.Net as my gateway, and I've checked the credential info and it all seems to be okay.
Jimmy Wu
Are you using the simulator or the live api? This error seems to only occur with the simulator. If you try updating your credentials to live credentials and testing it, you might get better results.
It appears that this error means that your Transaction Key is not correct and you should contact Authorize.net to have them check on the Login information and Transaction Key.
dave403891
Jimmy,
My ignorance is embarrassing, but I'm just trying a transaction. I don't believe a simulator is involved. Is this api? How do I update credentials to live credentials.
I'm going to contact the gateway do as you say, but will be happy for any further light and knowledge. Thanks.
Jimmy Wu
Once you have contacted the payment gateway, I can instruct you further on how to modify the credentials to the live ones.
dave403891
Jimmy,
As I was checking the accuracy of the gateway's transaction key in the PHP code on the confirm page, I discovered a space between the last character in the key and the closing (") mark. I deleted the space and everything worked well. I wanted to get back to you ASAP, so that you can get on to others. Many thanks.
Jimmy Wu
Great to hear that you were able to determine the issue. If you run into any additional issues, feel free to open a new thread.
dave403891
Issue not resolved
Jimmy, I just saw this post. Please note that I have another thread, because this issue involved remote processing. I've now reset the site for local processing and the issue is that I cannot get the order receipt page to render. Details, including the zip files you asked for are in the other thread. Hope you get this. This issue will finish the site.
Jimmy Wu
I will send you responses in the other thread. Thanks for the update and checking up on your issue.
