syntax error with eCart 4 and Universal Email 4
Thread begun 6/04/2010 12:17 am by rob256926 | Last modified 6/10/2010 5:59 pm by Jimmy Wu | 3510 views | 5 replies |
rob256926
I just updated to UE4 and am getting on error after I press "Submit Order"
Error reads: Parse error: syntax error, unexpected '<' in /home/wmadmin/public_html/WA_Universal_Email/WAUE_confirm_2.php on line 38
Line 38 in my file is: <div class=\"eC_Simple_Pacifica_Arial\" style=\"font-family:Arial, Helvetica, sans-serif; /* Font Style */ font-size:x-small; color: #2C2D2E; /* Neutral_Black */ width:514px;\">
Jimmy Wu
Try using this copy of the WAUE_confirm_2.php page and see if you get the same error.
rob256926
It worked perfectly.
For some reason the store images are getting a broken link in the email body. This was working before I upgraded my UE.
Also the Laura Ipsm text has reappeared in the email body as well. When I hit edit in the UE Interface, and try to delete it the Laura Ipsm text is not there either.
Jimmy Wu
What are the urls for the images that are not showing up correctly?
The text would be in one of the templates that is in your webassist/email directory. Check to make sure the text isn't in the email template there.
rob256926
Here is the link where the images are hosted.
I found the text. For some reason the template was put in WA_Universal_Email/WAUE_confirm_2.php
Jimmy Wu
And in the email, what is being referenced in there? Is it a link that looks like it should be working as well?
