Dreamweaver Crashes
Thread begun 6/03/2010 8:58 am by cal375160 | Last modified 6/03/2010 12:46 pm by Jimmy Wu | 2655 views | 4 replies |
cal375160
Dreamweaver Crashes
I was working with WebAssist attempting to build registration pages using DataAssist.
When I clicked "Finish" to allow Webassist to build the pages, Dreamweaver crashed. This is the second time it has happenned in 1/2 hour.
At one point I went back in DataAssist to change something and got the following Dreamweaver warning:
DW While executing onClick in WA_AppBuilder.htm, the following JavaScript error(s) occurred:
At line 2108 of file “Macintosh HD:Users:cal:Library:Application Support:Adobe Dreamweaver
CS5:en_US:Configuration:Commands:WA_AppBuilder.js”
tObj has no properties
I am using Dreamweaver CS5 and DataAssist 2.0.7.
Can you suggest what might be happening?
Thank you,
Cal Fox
Jimmy Wu
Are you saving your pages to a site stored on a local drive or are you saving to a site stored on a remote drive?
What steps are you taking to get the error message? I'd like to try to reproduce this error so that I can take a look at it.
When Dreamweaver crashes, are any pages generated or does it not create any pages?
cal375160
Dreamweaver Crashes
I'm storing everything on my machine and have a testing server (MAMP) on it also.
The DataAssist application starts the process as usual once I've entered all the data required and pressed "Finish" I see a stopwatch and it looks like it might be creating a page, then I see the stopwatch again and then it crashes.
No pages are saved by DataAssist (which they always have been in the past) so I have nothing to send you in the way of a finished product.
I am in the process now of uninstalling DataAssist 2.0.7 and reinstalling 2.0.6 to see if I can generate the pages that way.
Cal
cal375160
Dreamweaver Crashes
Forget it! OMG! I realize that I've already created the pages and that this really amounted to an attempt to create the AGAIN! Hence the crash (I think).
The extension I really wanted to use was Security Assist.
I'm so sorry I took your valuable time with this. Once again I feel really stupid.
Cal
Jimmy Wu
Its no problem. If you run into any additional issues, feel free to open a new thread.
