Adding fields to user registration PowerStore3
Thread begun 6/03/2010 8:57 am by admin140217 | Last modified 6/03/2010 12:46 pm by Jimmy Wu | 2156 views | 3 replies |
admin140217
Is it possible to add form fields i.e. check boxes and or text fields to the user registration/profile in powerstore3. What would I need to do?
Jimmy Wu
This isn't really something that is supported, so I can give you some pointers on how to implement this, but you would have to get it done on your own. Basically you would need to add the form field to the form on the registration page. Then create a database field to store the contents of that field. Then you would need to add to the insert behavior to insert the information into the database on the registration.
admin140217
Thanks Jimmy, I appreciate your input. I'm using PowerStore3 as a mix of purchacing a registration for a convention and an info bank on those registrations/purchases, this was the best solution to grow with the site and have the information available via the web.
Thanks again.
Jimmy Wu
No problem. If you run into any additional issues, feel free to open a new thread.
