How do I remove the bubble?
Thread begun 6/03/2010 6:05 am by dawn401382 | Last modified 6/04/2010 11:41 am by Jimmy Wu | 2909 views | 3 replies |
dawn401382
Please help - I have posted this problem before and after a week of trying still not been able to resolve the issue
I have been trying to remove the bubble but with no success, so have deleted old map and started from scratch.
location.html
Please can somebody advise me what code I need to remove from this in a really simple way as I am not a techy. thank you
The code is below if that helps:
function WAMapRef(mapObj) {
this.obj = mapObj;
this.directions = false;
this.icons = [];
this.markers = [];
this.addresses = [];
this.points = [];
this.getPointByAddress = getPointByAddressFunc;
this.addressFailed = true;
return this;
function WAMapPoint(theMarker, theAddress, theIcon) {
this.icon = theIcon;
this.marker = theMarker;
this.address = theAddress;
return this;
function getPointByAddressFunc(value,attname) {
if (!attname) attname = "street";
for (var x=0; x < this.addresses.length; x++) {
if (eval("this.addresses[x]."+attname) == value) {
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x]);
return false;
function getHTTPObject(){
if (window.ActiveXObject)
return new ActiveXObject("Microsoft.XMLHTTP");
else if (window.XMLHttpRequest)
return new XMLHttpRequest();
else {
return null;
function searchCache(searchStr, zip) {
var xmlDoc = null;
if (window.ActiveXObject) {//IE
xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
} else if(navigator.userAgent && navigator.userAgent.toLowerCase().indexOf('webkit') >= 0) { //webkit (Safari, Chrome)
var coordinates = '';
xmlDoc = getHTTPObject();
if(xmlDoc) {
xmlDoc.onreadystatechange = function() {
if(xmlDoc.readyState == 4) {
var x = xmlDoc.responseXML.getElementsByTagName("geocode_entry");
var geocode, id;
searchStr = searchStr.replace(/,/g, ''); //remove commas
for (i=0; i < x.length; i++) {
id = x[i].getAttribute("ID");
if (id == searchStr) {
coordinates = x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
return coordinates;
xmlDoc.open("GET", "_promaps_cache/_promaps_geocache.xml", false);
xmlDoc.send(null);
return coordinates;
} else if (document.implementation.createDocument) {//gecko (Mozilla, Firefox, Opera)
xmlDoc=document.implementation.createDocument("","",null);
} else {
return '';
if (xmlDoc != null) {
xmlDoc.async=false;
try {
if(xmlDoc.load("_promaps_cache/_promaps_geocache.xml")) {
var x=xmlDoc.getElementsByTagName("geocode_entry");
var geocode, id;
return x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
catch(err) {
return '';
return '';
function addToCache(fullAddress,zip, geocode){
httpObject = getHTTPObject();
if (httpObject != null) {
httpObject.open("POST", "google_javascript/promaps_geocache_.js", true);
httpObject.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
var entryId = fullAddress.replace(/,/g, '');
if (zip != '') {
fullAddress = fullAddress.replace(zip+',', '');
entryId = escape(entryId);
fullAddress = escape(fullAddress);
geocode = escape(geocode);
httpObject.send("sender=promapsforgoogle&action=add&entryId="+entryId+"&address="
+fullAddress+"&geocode="+geocode);
function wagmp_map_1() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_1')) return false;
var map = new GMap2(document.getElementById('wagmp_map_1'));
wagmp_map_1_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallMapControl());
map.addControl(new GMapTypeControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'plugins/google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'plugins/google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'plugins/google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
var address_0 = {
street: '[Address]',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"></span>',
full: '51.5591,-0.9518',
isdefault: true,
addressType: 'coordinates',
loop: '',
latitude: '51.5591',
longitude: '-0.9518',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
if (address_0.addressType == "coordinates") {
var cacheReturn = '';
} else {
var cacheReturn = searchCache(address_0.full, address_0.zip);
if (cacheReturn != "" || (address_0.addressType == "coordinates")) {
if(address_0.addressType == "coordinates") {
var latitude = address_0.latitude;
var longitude = address_0.longitude;
} else {
var latitude = cacheReturn.substring(1,cacheReturn.indexOf(",")-1);
var longitude = cacheReturn.substring(cacheReturn.indexOf(",")+1,(cacheReturn.length)-1);
var point = new GLatLng(latitude, longitude);
if (point && !isNaN(latitude)) {
wagmp_map_1_obj.addressFailed = false;
var marker_0 = new GMarker(point, icon_0);
GEvent.addListener(marker_0, 'click', function() {
marker_0.openInfoWindowHtml(address_0.infowindowtext);
if(!fromAddress.enabled || 'address_0' != 'address_0') {
if('address_0' == 'address_0')
map.setCenter(point, 13);
map.addOverlay(marker_0);
wagmp_map_1_obj.markers.push(marker_0);
wagmp_map_1_obj.addresses.push(address_0);
wagmp_map_1_obj.icons.push(icon_0);
wagmp_map_1_obj.points.push(point);
} else {
if (wagmp_map_1_obj.addressFailed) {
map.setCenter(new GLatLng(30, -98), 3);
wagmp_map_1_obj.addressFailed = true;
} else if (address_0.addressType == "address") {
geocoder.getLatLng (
address_0.full,
function(point) {
if(point) {
this.addressFailed = false;
addToCache(address_0.full, '', point);
} else {
var noZipAddress = address_0.full.replace((address_0.zip+','), '');
geocoder.getLatLng (noZipAddress,
function(point) {
if(point) {
addToCache(address_0.full, address_0.zip, point);
if (!fromAddress.enabled || 'address_0' != 'address_0') {
} else {
Jimmy Wu
Did you try removing this line as I suggested in your other thread?
dawn401382
Thank you it worked - the bubble has gone
Hi Jimmy
Thank you so much, this worked. I realised you had suggested this in the last post but think I had trashed the code so badly by then with all the suggestions that had been made, that it would never have worked. So starting again and doing this one simple line of code removal worked first time.
Big thank you for your help and being so patient
Jimmy Wu
No problem. Glad it worked out for you. If you run into any additional issues, feel free to open a new thread.
