Form looping
Thread begun 6/02/2010 6:01 pm by rich211354 | Last modified 6/07/2010 6:03 pm by Eric Mittman | 5946 views | 11 replies |
rich211354
Form looping
Hello -
I am trying to setup an email send for the first time with a simple file upload and a few fields. My form starts to process, but then fails. I've checked to make sure the folder has write access in case it needs to store the file temporarily.
I've attached the base form and then my WebAssist folder. The base form is located down in a clients folder, but it appears to be setup to reference the Webassist folder off the root.
contact.php
Thanks for any ideas
Rich
it looks like the problem is with the page you are sending the user to after the upload and email occur. The target page seems to have some problems and it will give errors when you try to go to this page by itself:
target.php
It seems that the Upload and email are occurring successfully as it is trying to send you to this target page afterwards. You can check it out by updating the go to page in the Universal Email. You should have it go to a new page that just has a message on it so you will know when you get there. You should then work out any issues with the email and upload after you have it redirecting like this. Post back if you have any more questions or if you encounter any further problems.
rich211354
Hi Eric -
Thanks. I made the target file into an html file for kicks to avoid any preprocessing that could get in the way.
Also, I think the real reason is that I need to tell the code to use a specific user to access my outgoing mail server. Would you know where I can change this code? Shall I just create variables in my main form php code for the server name and user credentials? Wonder why this isn't part of the DW extension, or did I miss it?
Rich
rich211354
Pear
just checked and my shared hosting does not have PEAR. How can I get this to work?
I'm on Win IIS
EDIT - just got this from my host:
we do not have PEAR. However, we do allow PHP Mail and Blat.exe which is windows version of sendmail.
If your host allows regular php mail then you do not need to choose the authentication option and PEAR. You can just set it up like normal without authentication. Just make sure that the host and port if needed are specified. Does your host require an additional from parameter when sending with the mail? If so you will need to check the option for this in the mail object settings in UE.
rich211354
Yes, as I said, my host requires me to pass it a valid host name and user account on the mail server. It is plain PHP mail().
Please tell me where I can set these? Where in the code do I set the host?
You mention the mail object settings, but you haven't told me where that is or what to change. I see references to it in some parts of the code, but
Please, I need to get this going today.
This waiting 24 hours is killing me.
Rich
PS - please open a specific case for me so we can work on this today and until it is resolved.
rich211354
Also, how can I get at the return values, if any, on the target page so I can test if the send occurred properly?
Any examples for this?
Eric, the bottom line is there really isn't any documentation for what you are talking about. I get that we can try and tell the functions that call PHP mail to pass server and port number(of course I need to pass sendfrom name as well), but there isn't an ounce of documentation that I can see past the DW extensions. I see 5 files that calls are made to and from linked from my contact for and the includes there in. I've tried adding code to the mail_php.php form but it doesn't work. I am also not confident that this is where you imply me to add these values. Developers need some documentation on how these files relate to one another in order to go changing them.
My apologies for not being more direct with the instructions. The mail object settings are edited in the Universal Email interface with the envelope icon. In here you can configure what is the SMTP server and other details. This is where you would put in the authentication if it is needed, however this authentication only works for PEAR mail. If you are using regular mail then you should not need to enter any credentials. You mentioned:
"my host requires me to pass it a valid host name and user account on the mail server. It is plain PHP mail()"
This statement is a little confusing to me. From what I understand the standard php mail() does not support authentication. If you mean that you need to set the from parameter then this is configurable within the mail object settings by checking the box. It will use your from address for this, so make sure that you enter your appropriate email address for the from. Let us know if you have any further issues with this.
rich211354
Thanks. I'll try this first thing in the morning.
Yeah, CrystalTech(a top 10 host) does some further testing of the email connections to prevent spoofing attacks of some kind. It must just not process the email if it doesn't come in with a valid sendfrom account.
Rich
Sounds good, let us know how it goes for you.
