Adding text input option to Product Detail
Thread begun 6/02/2010 7:03 am by Maplemac | Last modified 6/03/2010 3:44 pm by Eric Mittman | 2173 views | 3 replies |
Maplemac
Hi
I need to be able to add a couple of text input boxes to gather dimensions on the Product Detail page. This info then needs to be passed along with the other options to the order. Is this possible and if so how would I do it?
Any help would be appreciated.
Products_Detail.php?ProductID=1
Making this change would require using eCart and some custom coding. This type of customization should only be attempted if you are comfortable with using eCart. The idea is that you would start by adding in the text fields to the add to cart form. Next you would need to update cart object to include these new columns. Once you have done that can edit the add to cart server behavior to bind the new fields to the new columns.
This will get the info into the cart, the next things to do would be to update the display manager. This will require some custom coding to add in the bindings for these new cart columns. An easy way to do this woud be to drag and drop the new column values where you would like to see them in the cart display. You would need to update all of the cart displays including the confirm and receipt pages.
To store the details you will need to edit your database to add in the new columns in the order details table. Once you have done this you can modify the store order details server behaviors on the confirm pages to store the values in the newly added columns in the order details table.
This is an advanced update to the PowerStore and I would not suggest attempting this without an understanding of these steps and experience in using eCart. We cannot support this customization but we can give you pointers if you need them.
Maplemac
Hi Eric
That's exactly what I have started to do - we'll see how far I get before needing sone help again :)
If I can get this to work it will be exactly what the client wants.
Thanks for your excellent support.
You're very welcome. Let us know if you have any questions about the process or if you get stuck and we will help you with what we can.
