How to create the new form after deleted the Form
Thread begun 6/01/2010 2:56 pm by james276087 | Last modified 6/02/2010 3:26 pm by Jimmy Wu | 2516 views | 3 replies |
james276087
I'm having little (big) problems with contact form.
I got this message from hosting company:
open_basedir is set to include your entire account directory, you shouldn't need access to files outside your account directory. Please make sure you have configured the scripts to use the correct directory path, the absolute path to your web directory is /virtual/users/exxxxx-xxxxx/web/ (replace exxxxx-xxxxx with your real WebID, can be found in Website/FTP section)
Jimmy mentioned before that i might have some code before i created the form ...
How can I deleted all the files, folders and pages so I could start without any codes on my site.....thanks for reading
Jimmy Wu
CSS Form Builder wouldn't access anything outside of your user directory. The files generated use relative paths to access the files. One thing you want to check in your site definition is that the links relative to under local info is set to document, not site root.
james276087
thank you Jimmy
Jimmy Wu
No problem. Let me know if there are still other issues when you make that change and generate the pages again.
