vista xampp setup with unknown hitch
Thread began 5/31/2010 8:00 am by sunsabbath76401977 | Last modified 6/01/2010 12:44 pm by Jimmy Wu | 1620 views | 4 replies |
sunsabbath76401977Beta Tester
Hi
New to php.
Downloaded xampp and turned of IIS.
Ran the download.
Followed tutorial.
MySQL is running.
Apache is Busy...
Opened a Explorer browser and ran localhost/
Reads
Internet Explorer cannot display the webpage
What you can try:
Diagnose Connection Problems
Tried it.
"Local Host is not set up to establish on a connection to world wide web"
Is the problem, local?
Sabby76
Found problem
Ok Hi
Found the problem 1 inexperience, 2 just needed to double click the windows apache batch file in the xampp folder list to start apache running in the xampp control panel, after that the installation went verbatim.
Originally Said By: sunsabbath76401977
  Ok Hi
Even better
Apache 443 port was blocked via Skypes online connection.
Un-installed Skype and apache runs straight from the control panel.
Sabby76
victor278184
i think you better choose apache instead IIS since apache use by most hosting server.
if you run both as your Step no 1: "Downloaded xampp and turned of IIS." , make sure both does not listen to the same port (default :80) you can make apache use port 80 and IIS for 8080.
but again if you just learn dynamic programming.. choose only one server is recommended.
Jimmy Wu
Great to hear you were able to work out your issue. If you run into any additional issues, feel free to open a new thread.
This post has been deleted.
