Parse error
Thread begun 5/31/2010 5:39 am by mndavalos397956 | Last modified 6/03/2010 4:26 pm by Eric Mittman | 3118 views | 5 replies |
mndavalos397956
Parse error
I have this error:
Parse error: syntax error, unexpected ')' in C:\xampp\htdocs\cnh2\CSSMenuWriter\cssmw\menu.php on line 63
CS4 AND CS5
I clear the cache 1000 times ... always the same error
It looks as though there is a problem with the recordset code on your menu page. You should open up this page in DW and edit the recordset. When you do make sure to fill in any missing data that it asks for.
How did you create this menu? Was it created in CS4 or CS5? Did you configure the menu to have dynamic entries? Please post back with some details so we can look into this further with you.
mndavalos397956
I use CS5 .... but in CS4 i have the same problem ... always the line 63 .....
Yes ... I use a database whith categories an subcategories ... I send just de parent categories ....
HEELLLLLLPPPPPPP
Can you post back with a db export and detail the steps you have taken that give you this result, this will help us try to uncover the problem. If you can't post this info let us know so we can open a ticket for you.
mndavalos397956
I solve the problem .... manualy
All Recordsets had an error that I fixed manually. Now I wonder why these things happen with your products?, As happens with Data Assist ... simpre I manually correct errors caused by the "Wizards".
If you can post back with the db and steps you are taking that yield this result we would be able to look into this issue further. What were the steps you took to resolve the issue with the recordsets?
