eCart Shipping eCartDesignObject.js
Thread begun 5/30/2010 10:10 pm by david331670 | Last modified 6/03/2010 7:30 pm by david331670 | 2134 views | 3 replies |
david331670
I have created a new shopping cart.... PLEASE READ NOTE BELOW I THINK I HAVE CORRECTED THE PROBLEM
I have made the data base added the cart page and created add to cart items, it previews in my testing server. I now want to use the checkout wizard to create the final pages but I now have an error in the file "eCartDesignObject.js"
The other shopping cart I have made functions properly, and when I click on the display manager or checkout wizard in that site I dont get the error.
I do get the error in the new site??
I have reinstalled the ecart extension, deleted the macfilecache.txt file ( a well used path anymore) still no change see screenshot of error.
I read that someone else was having the same problem but no solution was posted that worked.
Please help with this issue.
David
More information.
I had the same files on my home computer, I tried the same thing, got the same result.
I created a new eCart site, Simple 4 pages no flowers.
Created database, linked database to site added a Cart object, created recordset, added "add to cart button" tested and all worked, tried to add display manager, same fault.
Multiple "command Z"
Then added a Cart object, created recordset, go to predefined Cart Page.php
Click display manager, PRESTO Worked, no error as above, Clicked checkout wizard, PRESTO worked again, no error as before.
I suspect that by creating "add to cart button" before creating Shopping Cart with display manager and checkout pages has somehow caused the problem.
I have just created a new site from scratch and it works with the above method.
DO NOT CREATE ADD TO CART BUTTON BEFORE YOU CREATE THE DISPLAY AND CHECKOUT PAGES.
Thanks for posting with all the info, it is very helpful. I have opened a ticket for you on this issue so we can look into it further. To check the status of your ticket or update it login and visit your support history.
Jimmy Wu
After doing some testing, we were unable to reproduce this issue. Are there any additional details you could provide about your setup that you could provide?
david331670
eCart
I am using a Mac Pro4, Quad-Core Intel Xeon 2.26Ghz 16GB ram OSX Snow Leopard 10.6.3
Using Adobe CS4 Suite, Dreamweaver CS4.
I regularly repair permissions.
I often have problems with the Webassist extensions, the cart set up etc. Tabbing from one item to the next does not save any selection, I must do it all very precisely, the wizards are always giving me problems. Sometimes I cant save what I have done because it ask me to fill in the details of a dialogue box that already have an input, I need to hit enter or return on many thing to have them accepted only to find on occasion that this finishes the edit and the dialogue extension closes. Trying to edit some pages with the wizards is difficult as they add the code to the page a second time, there is now way to edit the existing code in any structured dialogue box, only manually in code view.
There is no way to edit the details of the checkout wizard without starting over again and you end up reproducing all the checkout pages again.
In general I find that not many things work first time, they always seem to add unusable code that restricts the proper use of the extension. UEmail 4.0 an example.
The offending js file on one site worked ok on another web site.
Tres confused.
Regards
David
