Continue shopping not working
Thread begun 5/28/2010 8:54 am by Miguel | Last modified 6/02/2010 2:15 pm by Jimmy Wu | 3147 views | 4 replies |
Miguel
Hello im working with server side includes (ADDT) cause this site will not be moved to a php 5.3 server it will always remain on php5.2,but i have the cart page on its own page without the server sides i added the
error_reporting(E_ALL);
No errores display here
i also added at the end of the page
<?php var_dump($_SESSION); ?>
this displays the following
array(22) { ["KT_lastsiteroot"]=>  string(32) "15e3eacf32101fac18c32abf386ba185" ["tfi_listusers1_estado_u"]=>  string(0) "" ["KT_backArr"]=>  array(1) { [0]=>  string(59) "http://localhost/folder/folder/main.php?action=users" } ["KT_lastUsedList"]=>  string(13) "listusers1" ["tfi_listusers1_UserID"]=>  string(0) "" ["tfi_listusers1_foto"]=>  string(0) "" ["tfi_listusers1_correo"]=>  string(0) "" ["tfi_listusers1_nombre"]=>  string(0) "" ["tfi_listusers1_apellido"]=>  string(0) "" ["tfi_listusers1_pais"]=>  string(0) "" ["tfi_listusers1_edad_u"]=>  string(0) "" ["tfi_listusers1_level"]=>  string(0) "" ["tfi_listusers1_type_acc"]=>  string(0) "" ["tfi_listusers1_payment_usr"]=>  string(0) "" ["tfi_listusers1_coordinator"]=>  string(0) "" ["filter_tfi_listusers1"]=>  string(3) "1=1" ["sorter_tso_listusers1"]=>  string(20) "usuariox.UsersID DESC" ["default_max_rows_nav_listusers1"]=>  int(20) ["max_rows_nav_listusers1"]=>  int(20) ["WADbSearch1_planes_prod_Results"]=>  string(0) "" ["Ecart_Items"]=>  string(272) "2|WAECART|prueba2|WAECART|222|WAECART|0|WAECART|1|WAECART|8000|WAECART|Main|WAECART||WAECART|0|WAECART|8000|WAECART|1 prueba2 (2)§1|WAECART|prueba|WAECART|servicio de prueba|WAECART|0|WAECART|1|WAECART|9000|WAECART|Main|WAECART||WAECART|0|WAECART|9000|WAECART|1 prueba (1)" ["WAEC_ContinueRedirect"]=>  string(41) "/folder/main.php?action=detail&id=1" }
I also changed the continue behavoir to the following
// WA eCart Continue Shopping
if (isset($_POST["Ecart_Continue_100"]) || isset($_POST["Ecart_Continue_100_x"])) {
$Redirect_redirStr="main.php?Search_pro=&action=results&Search.x=48&Search.y=4&Search=Search";
if (true && isset($_SESSION['WAEC_ContinueRedirect'])) {
if ($Redirect_redirStr != "") {
$Ecart->redirStr = $Redirect_redirStr;
$Ecart->cartAction = "Continue";
Readed every post about this button and did changes suggested to those users but with no luck if i click continue shopping it just stays on the cart page but doesnt change to any, what else should i do or what am i missing?
Miguel
Nevermind fix it moving the order of stuff on top of the page, this behavoir has happened to me on multiple site but mostly when working with templates on this page i have no template, what i did was check other sites i made and saw the issue, it seems that the codes
// WA eCart Redirect
if ($Ecart->redirStr != "") {
header("Location: ".$Ecart->redirStr);
where placed at the wrong spot i moved it to the end just before <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
the wizard added al the show cart stuff but left that just after
$Ecart->GetContent();
after moving it things worked good.
Now this is not the first time i have to move stuff around after the wizards finish, i think WA should trouble shoot this why stuff are placed randomly or not placed in the correct order, but its not always for me it was just only when using templates but today it happened without a template on the page.
Jimmy Wu
Do you have some specific steps to reproduce the incorrect placement of the code? We would be glad to troubleshoot it if we were able to reproduce it consistently.
Miguel
No specific steps, but it always happens when i make a template with dreamweaver or if i use a premade one for example using dataassist telling it to use a template if i use the validator toolkit after it places always at the wrong spot the validation and i have to move them, or for example if i build a product page using a normal query made by dreamweaver if the page has a template after building the product page adding a repeat region just small stuff when i apply the add to cart button i have to move the libary or require files from place also the redirection stuff, if i dont have a template on the page it adds all fine until this last proyect, and the only new thing i have on extension is css form builder but i doubt thats the problem.
Jimmy Wu
Ok, I'll try those steps to see if we are able to reproduce the error and if we are I will log a bug for this.
