positioning
Thread begun 5/27/2010 10:42 am by jerry394338 | Last modified 5/28/2010 2:25 pm by Jimmy Wu | 1626 views | 3 replies |
jerry394338
positioning
How do I position a horz menu. See the link below. You will see a menu directly above the photo gallery that I need to move to the right so it lines up with the left border of the photo gallery
gallery.php
Jimmy Wu
If you put a div around the menu you should be able to make the div full width and align the menu to the right without any problems. Right now your menu is directly in the content div, so that is why you are unable to position it the way you want.
neilo
Hi Jerry,
Enclosing the menu inside its own div and adjusting the css for that div would certainly be the best practice, but a quick solution might be to just change these values in the CSSMenuWriter/cssmw2/menu.css:
ul#cssmw2 (Line 4):
margin: 0 0 16px 22px; /* Changed from 'margin: 0' */
ul#cssmw2 > li > span > a (Line 68):
width:96px; /* Changed from 'width:102px' */
Jimmy Wu
Yes, that certainly would work to position the menu as well. Thanks for the input on this neilo.
