Developer notes: Removing 'admin' directory and @@content-group@@ values
Thread began 5/27/2010 2:53 am by Laurent | Last modified 5/28/2010 9:02 am by Jason Byrnes | 796 views | 1 replies |
Laurent
here are the lines of code i get :
include('/var/www/vhosts/domain.net/httpdocs//WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, '@@content-group@@', '@@content-ref@@', false@@order@@);
1st bug concerns the missing directory, which in my case was "admin", as i see powerCms also uses a directory called admin, maybe it is causing the missing word ?
2nd one is more strange because yesterday it was looking ok the WA_getCMSContent() command, on today, after rebooting, i get these references @@... ?
Can you help please ?
Regards
Yeas, the developer notes will strip out any occurrence of the word admin, it will assume the admin directory is the PowerCMS one. You will either need to manually ad admin to the path, or move the PowerCMS files outside of the admin directory, if you go this rout, you will need to update the root url in the wa_settings table.
for the second issue, see the following post for a fix:
showpost.php?p=54402&postcount=7
