Powerstore 3 Content Edit Area not showing
Thread begun 5/26/2010 9:35 am by jamesf21212 | Last modified 5/27/2010 2:12 pm by Jimmy Wu | 1914 views | 3 replies |
jamesf21212
I did not encounter any errors during install, yet the store seems to be running into errors as the pages build. One of which is the text editing field for content which basically makes the site unusable. Any ideas?
Jimmy Wu
Could you be a little more specific as to which content area is not showing up for editing? I'm not sure which content area you're referring to, so I can't really look into the issue. Is it on the user pages or the admin pages? Which specific pages have the issue? Can you take a screen shot and attach it to your next response?
jamesf21212
code and file issues
I have been trying to troubleshoot this myself since my last post and have found that the pages are full of broken code and directories are missing pages. I have fixed the content edit. The "custom" directory in the HTMLEditor was missing(?). As for the other issues, there are many, they just seem to be sloppy code (example: <script> instead of <script type="text/javascript">). Any suggestions?
Jimmy Wu
Well, if you could start with one issue you're experiencing I can help you resolve it. I'm not sure how much I can help you if you just tell me that there's a wide range of issues you're running into.
What errors are the script tags causing?
