email sequence
Thread begun 5/26/2010 2:41 am by i.edwards384429 | Last modified 5/26/2010 1:27 pm by Eric Mittman | 1458 views | 1 replies |
i.edwards384429
email sequence
Hi
have a site where the verify email sequence is working perfectly. Have another where no email is received.
I've copied over the universal email directory but that has not solved the issue.
What files are called when the verify button is pressed? then I can do a file compare.
Incidentaly when I press the verify button it all appears to work OK
thanks
Ian
When this button is pressed the Universal Email server behavior on this page is triggered, it sends an email message from the WA_Universal_Email/WAUE_users_Profile_1.php file.
If you have the sites setup the same and the pages are the same then it might be a problem with the mail server that is specified. You will need to ensure that you have a mailserver specified that allows you to send mail un-authenticated.
