Unable to re-direct page
Thread begun 5/25/2010 2:51 pm by nickj | Last modified 5/26/2010 5:10 pm by Jimmy Wu | 2333 views | 3 replies |
nickj
I built an insert page and choose submit_thanks.php instead of the Results.php page but the the insert continues to go to the Results page. How do I make the page go to submit_thanks.php upon insert?
Why have the ability to set the redirect if it's "hard coded"?
Nick
// WA Application Builder Insert
if (isset($_POST["Insert"])) // Trigger
$WA_connection = $connAbstracts;
$WA_table = "abstracts";
$WA_sessionName = "WADA_Insert_abstracts";
$WA_redirectURL = "submit_thanks.php";
$WA_keepQueryString = false;
$WA_indexField = "abstract_id";
$WA_fieldNamesStr =
Jimmy Wu
That code looks like it will correctly forward to the submit_thanks.php page if there are no other redirects on the page. Can you send me the entire page and double check that you uploaded the page to the server?
nickj
Only the one I found!
Nick
Jimmy Wu
I'm not sure why your page would not be forwarding, but if you go to line 52 and hardcode the page to forward to like this, it should forward correctly:
header("Location: submit_thanks.php");
If the page is still not forwarding correctly, then it would seem the updates aren't making it onto the server.
