Quick cart on every page
Thread begun 5/25/2010 2:38 pm by Badger | Last modified 5/27/2010 1:26 pm by Badger | 2028 views | 2 replies |
Badger
I'm trying to get a Quick Cart appearing on most pages by putting it into a template but I'm getting the error:
Quick cart: Fatal error: Call to a member function TotalColumn() on a non-object....
Some pages are OK (EG Cart page) and others not (EG items page)
Is there something I need to add or delete to make it work or is the template method too much.
make sure that the cart require_once statement is before the getContent call, for example:
//WA eCart Include
require_once("WA_eCart/WA_Store_Cart_PHP.php");
$WA_Store_Cart
->GetContent();
if the $WA_Store_Cart->GetContent(); command where before the cart require_once command, you would get the error you are receiving.
Badger
Thanks for pointing me in the right direction. The order was OK but I had a clash of requests. The best way around it is to create a new template, pop the quick cart into it, delete the php code at the top and pop it back in on the individual pages where needed (eg not the cart page as it's there already).
