Back to cart after registration
Thread begun 5/25/2010 12:17 pm by Badger | Last modified 5/27/2010 6:13 pm by Eric Mittman | 2807 views | 5 replies |
Badger
Is there a way to retain the cart details in a session after being asked to register?
Using eCart5 with SA on checkout pages the sequence for a new visitor is:
Add item(s) to cart
Go to checkout
Asked to log in or register is new visitor
New visitor registers
On clicking on register button you're returned to the cart with the original item(s) still present.
The cart itself maintains all of the details in session variables. Once the items have been added to the cart then they will remain in the cart for the life of the session. So if you have a user login or register after adding items to the cart when they return to the cart page those items should remain in the cart. Are you experiencing something differently from this? If so please describe what you are experiencing after these various steps.
Badger
My first test returned to an empty cart page after registration. Now it seems to be working so obviously didn't test it properly.
Next question is having returned to the cart with the original items there, is it possible to be logged in after registration so when you select Checkout you don't need to log in.
I think that users should be verifying their email address first, then they are logged into the site.
If you are not verifying the email address then you can automatically log them in by storing the proper values in session variables. If your logged in rule is based on the userID then you can set the session variable to the just logged in user to have it 'auto login' the user.
On the page that you go to after inserting the user you could also have an authenticate user server behavior that runs before page loads. This will only work if you are not encrypting the password for the user, if you are then this will not work.
Post back with any questions that you have about either of these and I will help with what I can.
Badger
I like your method but, I feel the customer should be asked to sign it after registration. So I've left the sequence as is but duplicated the login page to make one just for registration that thanks you for registering and better describes what to do next by pointing to the shopping cart. A manual fix if you will but I might try to code your solution later though.
Many thanks
Sounds like a good plan, let us know if you have any other questions about it.
