menu not showing on frameset
Thread begun 5/25/2010 7:37 am by hivihk406182 | Last modified 5/25/2010 11:27 am by Jason Byrnes | 3074 views | 3 replies |
hivihk406182
I would like to create a horizontal menu on the upper frame, but it cant be shown, how can i make it overlap on the lower frame? I am using DW8
URL:up8.html
The only way to have a menu in the top frame show correctly would be to use java script to show the menu items in the bottom frame. this is not something that is supported by menu writer.
Menu Writer will not be able to work in your frames design in this way.
Are you using frames as a means to have the same menu on each page or is there another design reason for using frames?
If the choice of using frames is to create one page to manage the menu, you should consider using a Dreamweaver Template instead.
Add the menu to the template and the menu will be added to each page derived from the template.
hivihk406182
would you mind tell me more about how to add the css menu to the dreamweaver template? thank you!
See the following tutorial for information on working with templates in Dreamweaver:
dw_templates.html
adding the menu to a template is no different than adding it to a standard page.
