How to reduce size of entire gallery
Thread begun 5/24/2010 8:44 pm by designer407046 | Last modified 5/25/2010 11:20 am by Jimmy Wu | 1621 views | 1 replies |
designer407046
I am trying to fit the power gallery into a space smaller than the default size of the power gallery frame. Is there a way to shrink the whole gallery, not individual images? Will it auto adjust if inserted into a smaller div tag, for example?
Jimmy Wu
The changes that you would need to make are dependent on the gallery you're trying to edit. Unfortunately in this version there is no general settings that need to be changed to get the gallery to change size. If you've decided on which layout you're using, let me know and I can better instruct you on how to edit the size of the gallery.
There are also quite a few other threads on how to resize the galleries:
search.php?searchid=822766
