3 DDs, last one getting value for 2nd one, not 3rd one
Thread begun 5/24/2010 2:02 pm by max279608 | Last modified 5/25/2010 11:52 am by max279608 | 4186 views | 8 replies |
max279608
I am using Dreamweaver CS3. I have a 3 dropdown menues and 3 recordsets for auto parts. Second DD gets populated with models when I click on the first DD holding the makes. But the third recieves the value in the 2nd DD, not the recordset for the 3 DD when I click on the 2nd DD with models...
My recordsets are as follows.
rsParent = select all the makes
rsChild = select all the models from the selected make from rsParent
rsTarget = select the years for the model selected in rsChild, but it only populates the 3 DD with models, not years
The rsTarget displays the data I want in the recordset in testing. I think it has to do with the runtime value I am giving it in Dreamweaver...? Sorry been working on this for days, tired and going in cirlces.
I am including my php file with the DD's.
Any help is really appreciated, I am whooped.
Thanks!!!!
In the populate List From Array behavior that is applied to the Parent list, you are using the rsChild Dynamic Array (rsChild_WAJA):
<select name="parent" size="10" onchange="WA_FilterAndPopulateSubList(rsChild_WAJA,MM_findObj('parent'),MM_findObj('child'),0,0,false,': ')">
Again, you use that same dynamic array in the Populate List from Array behavior that is applied to the Child List (rsChild_WAJA):
<select name="child" size="10" onchange="WA_FilterAndPopulateSubList(rsChild_WAJA,MM_findObj('child'),MM_findObj('target'),0,0,false,': ')">
to use the rsGchild array, that code should be:
<select name="child" size="10" onchange="WA_FilterAndPopulateSubList(rsGchild_WAJA,MM_findObj('child'),MM_findObj('target'),0,0,false,': ')">
max279608
I think it is in how I am passing the runtime value
I made the change to rsGchild, which makes sense. But now it passes nothing. I think now it is in my value I am trying to pass to the rsGchild... This is what I have:
$models_rsGchild = "EL";
if (isset($rsChild)) {
$models_rsGchild = $rsChild;
mysql_select_db($database_connTravis, $connTravis);
$query_rsGchild = sprintf("SELECT cars.From_dt, cars.To_dt FROM cars WHERE cars.Model = %s ORDER BY cars.From_dt", GetSQLValueString($models_rsGchild, "text"));
I am not sure what to put as runtime value. I want what is selected in the child list. I used $rsChild...? should it be something like $_POST['child'] ?
No, you shouldn't filter the recordset at all, that will be done using client side javascript when the select list is changed.
max279608
Still not working
I have attached my table and the file. This is what I am trying to do for an auto parts store. This is their data I have to work from.
First select list populate with makes (make is distinct in recordset)
Second select list populated with models (model is distinct in recordset)
Third select list is populated with the from and to list of the model selected. (year needs selected make to select year info)
I get First and Second list to populate, not third.
I really appreciate your help. I just can't get it to work. THANK YOU
Couple of problems:
1) the rsGchild only returns the date columns:
FROM cars
it needs to return the model column as well:
SELECT cars.Model, cars.From_dt, cars.To_dt
FROM cars
2) In the Create Dynamic Array(rsChild), the Child ID is bound to the Make column, it should be set to the model Column instead.
max279608
display the two dates in list
Hi Jason,
That worked. I have one last issue. I am trying to display both the from and to date in the select list.
I added the to date into the array, then added it into the list and it only shows the from date? Any idea what I am doing wrong?
I can not express how helpful you have been. Is there a place I can also post how great the support team has been? You guys are AWESOME!!
I attached and commented the two changes I made. Again, thank you!
The purchase of DD extention was well worth it!!!
use the CONCAT function in the SQL for rsGchild recordset.
SELECT cars.Model, CONCAT(cars.From_dt, '-', cars.To_dt) as FromToDate
FROM cars
the FromToDate column wont be availabel for selection in the Create Dynamic Array wizard, but you can change:
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_rsGchild["From_dt"])."'".";\n";
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_rsGchild["FromToDate"])."'".";\n";
max279608
Thank you!
Again, you have really helped. It works now. Anyone concidering buying this product. the timely support is unheard of with other products!
Thanks!
