User level access
Thread began 5/23/2010 1:25 pm by Pardall1955 | Last modified 5/24/2010 1:56 pm by Pardall1955 | 967 views | 2 replies |
Pardall1955
User level access
I have set up a group (USERS(2) & ADMINS(3)) which gives them their respective rights to the cpanel, but a also have another 2 levels Administrators(3) and Visitors(1) by itself
As I login as Users & Admins when go to pages that only administrators have rights, it sends me to the not_authorized.php page, but when I log out and hit the back page on the browser, it allows me to see the pages again.
If I login as Administrator, it gives all the rights to modify, add, etc. But when I log out and hit the back page on the growser, it also allow me to see the pages again, except that it only allows the same rights as the Users & Admins, to see and search.
On both cases it should not allow me back into the cpanel at all. I also clear the browser cash and it still allows me to get back into cpanel and visualize the the Users & Admins pages. It's weird. I've done other sites and looked over the code and it's all the same and on this one it gives me that problem.
Another question: Someone already had posted previously but I still didn't quite get it.
If you have everyone using the same Login page, administrators, members, users and perhaps visitors, can you redirect each person to their respective pages or directories, can you make a CASE inside of the login page to where you can give the option for each and every type of login.
Ex.
Case()
if (visitors = 1 goto VISITORSDIR/index.php
else)
if (users = 2 goto USERSDIR/index.php
else)
if (administrators = 3 goto ADMIN/index.php
else)
If something like that is not possible at the moment, can you people consider implementing it in the near future Security Assist Plug-In.
Your help is much appreciated,
thanks.
most likely the groups you are creating in the access groups manager have a blank value in them
In the access groups manager, try clicking below the last text value, if you can make a selection, there is a blank value and it should be removed.
To conditionally redirect to another page based on the logged in users user level, you could add a switch case statement on the page the login redirects to. In php the code would look similar to:
switch ($_SESSION['userLevel'}) {
    case
1:
header("location: VISITORSDIR/index.php";
        break;
    case
2:
header("location: USERSDIR/index.php";
        break;
    case
3:
header("location: ADMIN/index.php";
        break;
Pardall1955
Yes, I would never guess that those blank spaces would do such a thing, I have 2 blank spaces there. But then again, it´s by making mistakes that we learn how to get around them.
I will try the other solution and see if it works, that would be great not having to create more than just one login for all different levels.
Thanks.
