Email not being sent with UE307
Thread begun 5/23/2010 10:57 am by omarmacias376396 | Last modified 5/26/2010 11:15 am by Jason Byrnes | 5184 views | 10 replies |
omarmacias376396
I have created a contact form with CSS Form Builder and then apply the Universal Mail 3.0.7. but the email is not being sent.
My hosting provider, give me this information to send the emails:
Outgoing mail server: mail.golf4baja.com (server requires authentication) port 26
Outgoing mail server: (SSL) web2.xpress.com.mx (server requires authentication) port 465
Please find attached the PHP code generated by Universal Email.
Also here is the test link of the contact page:
contacto_omd.php
Could you please give me a hand?
since the server requires authentication, you will need to configure Universal Email to use the PEAR mail for SMTP mail object.make sure your host supports PEAR Mail, this is the only mail object ion Universal Email that supports authentication.
omarmacias376396
Thank you Jason, I have tried to do it through the pearl way and still not working, also I have tried to leave all blank in the email object tab. I know the server is working because I upload a simple contact form generated by me and is working ok.
Universal Email 3.0.7. “Not working” link:
contacto_omd.php
The other “working” contact form link:
contact_omd.php
Also is attached the code of the working form (contact.php)
the main diffrance that I see in your contact script is that you do not specify the smtp server, this will cause it to use the default smtp server that is set in the PHP.ini file.
In universal email, try leaving the smtp server and port fields blank so the PHP defaults will be used.
Also, on the from tab, do not set a from name, only the from email address, some server will not work correctly if a from name is specified.
omarmacias376396
Jason, following your instructions I have created a new FORM with CSS form builder and then apply the Universal Email 307 and still not working. I will like to explain the steps so maybe you notice that I’m doing something wrong:
Step 1: Create the form using CSS From Builder (see image step_01.png)
Step 2: Insert/webassist/universal email. In the Email Object tab I have use Mail and only populate the return path, everything else left empty (see image step_02.png)
Step 3: In the general tab I have configure the subject, trigger, and go to page (see image step_03.png)
Step 4 and Step 5: In the from tab, I have configure only the from email using the lighting bolt (see images step_04.png and step_05.png)
Step 6.: In the To: tab I just add to test emails (see image step_06.png)
Step 7 and Step 8: Body tab, I just add the comments information. (see images step_07.png and step_08.png)
Note: I will add one more comment to add the rest of the images since I can only upload 5 images.
omarmacias376396
.......3 more images
Thank you in advance for all your help!!
when the form is submitted, does it go to the redirect page you set in universal Email?
Please send a copy of the page.
omarmacias376396
Yes, after submitting the form the page is redirected to the thanks page (contacto_gracias.php), It looks good but the mail never arrives.
the problem is the forms action.
It is set to post to the contacto_gracias.php. the form is being posted directly to the contacto_gracias.php page, it does not stop on the contacto_omd.php page first.
<form class="GP001_simple" id="ConCaptcha_GP001_simple" name="ConCaptcha_GP001_simple" method="post" action="contacto_gracias.php">
change the forms action to post to the contacto_omd.php page to trigger the universal email behavior:
<form class="GP001_simple" id="ConCaptcha_GP001_simple" name="ConCaptcha_GP001_simple" method="post" action="contacto_omd.php">
omarmacias376396
Jason, now it’s working; you found the problem, who knows, knows! Thank you for all your help and have a great day!
