cs5 compatibility
Thread begun 5/23/2010 10:50 am by i.edwards384429 | Last modified 5/28/2010 7:36 am by Ray Borduin | 3537 views | 5 replies |
i.edwards384429
cs5 compatibility
Hi
just got DW web premium, does anyone know if the modules used in PS3 are cs5 compatible?
thanks
Ian
Jimmy Wu
We haven't done any testing using PowerStore and CS5. It should be done shortly (if I'm not mistaken) and there should be updates on all our products and their CS5 compatibility.
i.edwards384429
update
Hi
thanks, I'll carry on with CS4 at the moment then
Ian
Michael Lekse
All of our solutions including PowerStore work fine with CS5. They are just a set of PHP pages.
i.edwards384429
update
Hi
perhaps I was not precise enough ;-)
I realise PS3 is just a set of pages but if for instance I want to modify the shipping I need ecart so I suppose my question should have been
" are the extensions used in PS3 cs5 compliant"
cheers
Ian
The code itself won't change for CS5 compliance... however we used most of our extensions in one way or another building the powerstore and they are not all cs5 compliant.
If you own powerstore there is no reason why you couldn't open up powerstore files with cs5, but not all extensions used on all pages will be cs5 compliant for several weeks yet. There will be no update to powerstore itself once the extensions are all updated.
