not working in Dreamweaver CS5 ?
Thread begun 5/22/2010 11:04 am by rodeto407814 | Last modified 6/24/2010 12:32 pm by Ray Borduin | 6003 views | 8 replies |
rodeto407814
I just downloaded the extensions but I cant get it to work in Dreamweaver CS5. I just can't find it in the menu although the extension manager says it's installed correctly.
Any help is appreciated.
MikeH
Hi
Pnly extensions so far for CS5 are:
SiteAsist Pro
CSS Menu Writer
CSS Sculptor
Anything else is not currently checked for compatability.
Mike
anonymous
Keep in mind that none of the WebAssist extensions have yet been updated for CS5. While I have found that the majority of the ones I use have worked, WebAssist has not released the specific updates yet... and I have not tried this particular one so I could not say one way or another. Maybe a WebAssist engineer can clarify if this one will need an update to work.
Regards,
Brian
rodeto407814
Thanks guys for the replies.
I guess that I had to look better before ordering the extension and make sure it was compatible with CS5.
Right now it's not working so hopefully an update will come out soon.
We are working hard to test, fix, and certify all of our extensions to work with CS5. It should be available soon.
rodeto407814
Thanks for the info. Look forward to it.
kkc3388367056
CS5 Support
Will you notify us by e-mail when your applications have been verified with CS5?
rodeto407814
The application has been modified and a new version has been released. As far as I can tell right now things are working just fine with the new version.
I believe our entire product line is now CS5 compatible.
