Dreamweaver 8 & Universal Email 4
Thread begun 5/22/2010 1:51 am by steve355714 | Last modified 5/22/2010 3:21 pm by anonymous | 1417 views | 1 replies |
steve355714
I know the system requirements for UE4 specify DW CS3 or CS4. But for all I know, this might be required by Adobe. So I'm asking for an honest answer as to whether UE4 works with DW8.
(I'm quite sure it *could* work with DW8 if backward compatibility were seriously valued by WebAssist, or permitted by Adobe. So I'm just wondering if it does work with DW8 but the compatibility is undocumented or unadvertised.)
Thanks.
anonymous
Steve,
WebAssist's policy has typically been that current versions of their extensions will be supported on the most recent Dreamweaver and ONE version back. In the case of UE4, because it came out late in the cycle of Dreamweaver CS4 and is now being updated for CS5, this is particular case where the update will probably support CS5, CS4, and CS3.
I am not sure I would try it with Dreamweaver 8 unless a WebAssist engineer or employee could verify that it could work. I'm not even sure that DW8 has the necessary extension engine to power the new features that were packed in UE4 - so it's not that WebAssist doesn't have backward compatibility in mind but more so a limitation of older software and WebAssist's desire to be on a more current approach.
Regards
