Installation of PowerStore
Thread begun 5/21/2010 8:14 pm by admin400861 | Last modified 6/01/2010 6:40 pm by admin400861 | 7240 views | 10 replies |
admin400861
Hi Thanks,
I have purchased powerstore 3 and have completed the first step of upload. Can you please advise the next step, it says open browers window and installation wizard will set up? How do i do this?
i.edwards384429
update
Hi
I'm assuming you are installing to a live server rather than a test on your own system.
In order it's quite simple.
1. Ftp the complete ps3 download to your HTdocs directory on your web server (this may take some time)
2. COntact your ISP and request a mysql database they will supply you with the following:
Database location ie an ip address
Database name
Database password.
3. Open up your web browser and type in your domainname.com
4. By default the webserver will be set to open a default file of index.php
5. Index.php will open and run a quick test it will ascertain that you have no database connection setup. It will run through the setup and configure your site. (it will ask you for the details from 2)
6. When setup is finished you will be in the admin section where you can add products and alter the content using theCMS.
OK thats it a simple shop setup. From here on it you can change oodles of things:
Use the CMS to change content
Use the CSS to change colours layout
etc etc
As a personal preference I set shipping and payment to none during the setup and then when I* have the design stc correct implement paypal etc.
If you need any mopre help just post
HTH
Ian
admin400861
im pampered
Hi Ian,
When i type in my ftp address i sign in a takes me too a FTP root page. 'download to your HTdocs directory on your web server' ????
I am new to all this and am having a heap of trouble for somthing that seems really simple.
i.edwards384429
update
Hi
who is your ISP?
normaly when you register a domain, they give you all thje ftp settings.
Normaly you ftp your files into the htdocs directory . It is this directory that the web server reads to "publish" the web site.
Let us have your ISP and then we can advise you better
cheers
Ian
admin400861
Response
My ISP is optusnet broadband (Australia) . And my web hosting provider is www.crazydomains.com.au, i have the 'My web host' package. My domain name is also with crazy domains. Before i bought the hosting i double checked if the requirments for Ps3 would be compatible and yes it is.
Where would i find htdocs directory?.
i.edwards384429
update
Hi
if you have not already look at this link
publish_your_website.htm
when you have uploaded simply type into yout browser
www.yourdomain.com ( ie your domain name)
if it has been uploaded correctly then you will see the database setup sequence start
HTH
Ian
admin400861
response
Thanks for all your help. Everything is installed.
Just another thing, how do you get a password and user name reminder in the admin section to log in if lost or forgot.
i.edwards384429
update
Hi
I suspect that function would have to be hard coded but if you look at your tables using phpmyadmin or similar in the table wa_settings both username and password are listed there
HTH
Ian
admin400861
Respond
Ho do i upload my site once i have completed? I am using dreamweaver, do i need to upload it there? DO i need to upload via dreamweaver if i just alter 1 thing for example add a new product?
thanks
i.edwards384429
update
Hi
you upload your files using any ftp client and the settings provided by your ISP. Normaly your ISP recommends one, I suppose the most popular are cutetfp, wsftp etc etc. There are loads of free one out there.
DW had a built in FTP client which is perhaps a bit flakey. You setup the connections details in your site definitions and then in the site file panel you will see a double arrow button with flyout that says syncronise. Press that and it should syncronise your remote and local folders.
If you use the syncronise button only changed files will be uploaded.
HTH
Ian
