Create a preset in CSS Sculptor that is not Cabo Sunset
Thread begun 5/21/2010 9:07 am by kirsten407651 | Last modified 6/28/2010 7:23 pm by Jimmy Wu | 6471 views | 15 replies |
kirsten407651
As instructed by Super Suite I am trying to generate a preset from CSS Sculptor using the Output tab.
To get to the Output tab I select customise CSS which means that it reverts from my selection of Moab to Cabo sunset and it's associated images.
How do I get round this eg creating a preset that isn't the default
Many thanks
MikeH
Hi
This problem was created while I was working with Jimmy on another problem I did mention to them that this was an issue but it seems to have been missed in this update the way I fix it is to replace the wacs_quickinsert.js file that is in your
C:\Users\Your_Username\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\Commands
folder on windows find the AppData folder by using the %AppData% in file manager (works for ALL indows version)
You would need to replace it with the previous versions wacs_quickinsert.js not sure if that would break CS5 compatability though.
Possibly WA can confirm that we can still use the previous version if not Ill try it later and post back.
Mike
I have opened a ticket for you on this issue Kirsten, you can update the ticket or check on it's status by logging in and visiting your support history.
To Mike, if your workaround is doing the job for you currently that is good to hear. If you would like for me to open a ticket for you as well just let me know.
MikeH
Hi Eric
I can save you lots of messing around and time. During the tracking of another bug which is now fixed these lines were added to the file wacs_quickinsert.js
495
496
497
if you comment them out or remove them Sculptor will work without a hitch and you can change preset as you wish.
The lines look like this:
//Need to reset the global index to fix bug 6299 - DC
wa.onchange.designType();
wa.onchange.design();
These are the lines 495, 496, 497. I hope that helps in saving you time.
Mike
Thank you very much for pointing out the specific code changes that need to be made. I will ensure that the engineer working on this is aware and checks the result of commenting out these lines.
MikeH
Hi Eric
Your welcome of I have tried it on my clean PC and all certainly seems to run with no issues so hopefully this will be verified.
Mike
Indeed, thanks again. Keep your eyes on this thread to look for any update.
Jimmy Wu
Looks like that fix wasn't implemented correctly, so if you take it out those lines its fine. You actually only need to remove this line to get it working:
kirsten407651
Creating new preset
While it seems there is still a problem creating a preset that is not the default I decided to go ahead creating new presets thinking I can customise once I had created the Site with SiteAssist.
I have followed the steps to create a new SiteAssist layout using the Preset Manager, but after creating the new layout name my choice is to choose a design type and then the same design styles presets. The instructions say I should be able to choose from a sculptor menu list which would include my new presets. no matter where I look I can't find them. I have created at least three.
How do I make them appear as an option
You should see an edit button in SiteAssist where you choose your preset. Click that and you can add a new one based on your siteassist template and menu writer menus.
