Radio Group: Error Generating: buildFieldGroup
I am trying to create a radio group and every time I get the following error:
ReferenceError: reference to underdefined property "fieldName"
Please advise.
Please advise.
This looks like a js type of error from within the tool. You should try clearing your cache file to see if it helps you get past this error. Please give this a try and let us know if the problem persists:
If you continue to have this problem post back and include the steps that you are taking within the interface to get this result.
There is nothing on that document relavant to my issue.
I have cleared the cache and the problem is persistant.
All I am doing is trying to add a radio group to a line, add a new line or a new set and the error keeps coming and the radio group does not display on the preview or the page.
buildFieldGroup
Please advise :)
There is one more thing that you should try to overcome this error. Your configuration folder may have become corrupted, here are the steps you can take to rename the folder and undo any corruption that may have occurred.
showpost.php?p=12293&postcount=2
If this does not resolve the problem for you let us know and I will ensure that a ticket is opened up for you on this issue.
