PowerGallery and eCart
Thread begun 5/20/2010 12:24 pm by sfurley1983390133 | Last modified 5/21/2010 10:08 am by Eric Mittman | 1460 views | 1 replies |
sfurley1983390133
Hi I'm not sure if this is possible but i thought i would just check,
I have a website that has already been created using roman cart, one section of the site would be great if it was possible to click on it and add a "add to cart" button within the expandable box (I have pasting the code in which works to an extent but i'm not sure if this is the best way to do it.)
Thank you in advance
In the index page for the gallery you are working with there is a div like this on the page:
<div class="fullsize">
This is the div that the larger picture will be in. You can add your code inside of this div to have the button next to the image. If you are wanting to add an image to your cart or something similar you will probably have to do some customization of the js for the gallery to set the id of the image for the add to cart button when the images change out.
