Can't Browse Server all of a sudden
Thread begun 5/20/2010 12:16 pm by andrea396181 | Last modified 5/21/2010 5:26 pm by Eric Mittman | 2536 views | 3 replies |
andrea396181
When I'm trying to edit a link in PowerCMS (1) and click "Browse Server," I'm suddenly getting the following errors:
Warning: include_once(MDB2.php) [function.include-once]: failed to open stream: No such file or directory in /home/coreyoga/public_html/cms/HTMLEditor/editor/plugins/kfm/initialise.php on line 174
Warning: include_once() [function.include]: Failed opening 'MDB2.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/coreyoga/php') in /home/coreyoga/public_html/cms/HTMLEditor/editor/plugins/kfm/initialise.php on line 174
Fatal error: Class 'MDB2' not found in /home/coreyoga/public_html/cms/HTMLEditor/editor/plugins/kfm/initialise.php on line 176
It's always worked before, and I haven't made any changes to the server. Wassup?
Thanks,
Andrea :-)
I'm not sure why you would be getting this error if it was working correctly before. The file referenced is usually found in the kfm folder inside of includes > pear. I'm including a copy of it here for you in case you can't find it. You should check to see if it is in the following location:
HTMLEditor\editor\plugins\kfm\includes\pear
If it is not then you should add it here. If you can find it here then you may need to copy this file to the same location as the file:
Let us know how it works for you.
andrea396181
Fixed!
Thanks, all is well now.
Andrea :-)
Glad to hear that, let us know if you have any other questions.
