No Email Sent
Thread begun 5/20/2010 11:30 am by christine310921 | Last modified 5/24/2010 7:58 am by christine310921 | 2026 views | 3 replies |
christine310921
No Email Sent
I have created a Registration for users but when I tested found that no email is being sent from the registration_EmailPW.php page. The code is as follows:-
<?php require_once('Connections/connClosets.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("mail.designthecloset.com","25","","","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["Send_x"])){
//WA SecurityAssist Email object="Mail for Linux"
$WA_Auth_Parameter = array(
"connection" => $connClosets,
"database" => $database_connClosets,
"tableName" => "registration",
"filterColumn" => "RegistrationEmail",
"columnValue" => "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."",
"columnType" => "text",
"usernameColumn" => "RegistrationUserName",
"passwordColumn" => "RegistrationPassword",
"selectColumns" => array(""),
"sessionVariables" => array(""),
"successRedirect" => "registration_LogIn.php",
"failRedirect" => "registration_EmailPW.php",
"keepQueryString" => TRUE,
"toAddressColumn" => "RegistrationEmail",
"fromAddress" => "registration@designthecloset.com",
"fromAddressDisplay" => "Design The Closet",
"subject" => "Registration Details",
"mailBody" => "User name: [RegistrationUserName]\nPassword: [RegistrationPassword]",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
Are you able to get the email that is sent when the user registers? Are you using the same information for the emailing on your forgot password page? If so please post back with copies of both of these pages in a zip archive so that we can take a look. If you are able to get emails from one script then you should be able to get the emails from the other scripts in the site as well.
christine310921
Email Zip
Here are the pages security assist created. I am not getting an email at all.
christine310921
Fixed the problem
Just to let you know that I have fixed the problem regarding email not being sent containing the password.
Thanks for all your help.
Christine
