Add Amount to UPS Shipping
Thread begun 5/20/2010 10:29 am by rdubill357341 | Last modified 5/24/2010 3:27 pm by Jimmy Wu | 2976 views | 5 replies |
rdubill357341
OK - I have the UPS shipping amounts being returned correctly after setting up Ecart.
What I'd like to do now is take the shipping amount returned and add 15% to it.
I went into the ecart object and set up a rule under shipping to take the amount returned and apply this percentage.
When I click OK to save it and go back into the ecart object to view it it is gone.
Using ecart 4.5.2
Suggestions?
thanks
Jimmy Wu
When you say you go back into the eCart Object to view it and its gone, what do you mean? Is the UPS shipping rule not there or is the addition not there?
When you want to add 15% to your shipping charge, you can try setting up to use times instead of add and set the value to 1.15. I'll attach a screen shot so you can see how it is set up. Once you've applied the 1.15, try hitting tab to set the focus to another field before hitting ok.
If you're still having trouble with adding the rule, please explain in more detail what steps you are taking.
rdubill357341
UPS Shipping
When I am on screen to add the calculation on the bottom I enter times 1.15.
I tab - then click OK.
I go back into the ecart object and it is back to plus zero.
the 1.15 is gone.
thanks
Jimmy Wu
I'm not sure why you aren't able to make the modification through the interface, but you can manually add the multiply by 1.15 by opening up your WA_eCart/[storename]_PHP.php file and doing a search on the name of the rule without spaces. So if your shipping rule is called USPS Shipping, search for USPSShipping. Then you would add * 1.15 to the $totalShipping variable like this:
//eCart Rule
function WAEC_store1_USPSShipping() {
$totalShipping = 0;
if (true && (("USPS"=="USPS")&&(isset($_SESSION["store1_USPS_Quote"]))&&(floatval($_SESSION["store1_USPS_Quote"]) != 0))) {
$totalShipping += floatval($_SESSION["store1_USPS_Quote"]) * 1.15;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
the part in bold is what you want to add.
rdubill357341
Add to UPS Shipping
Jimmy - many thanks!
That did it!
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
