Remove bubble or change the depth of it
Thread begun 5/20/2010 9:23 am by dawn401382 | Last modified 6/01/2010 2:05 pm by Jimmy Wu | 5275 views | 9 replies |
dawn401382
Hi
Please could someone advise me how to remove the address bubble or change the depth of it - I only have a small map so the bubble is taking over.
PLEASE - I really need an idiots guide on how to do this as changing the coding is not familiar ground for me
Thank you
Jimmy Wu
If you could post a link to the map I could take a look at the JS and give you instructions on how to remove the popup.
dawn401382
REmove bubble or resize
Hi
Thank you so much that is really kind of you - the link is
location.html
please me know if you need anything else.
Jimmy Wu
In your google_javascript/wagmp_map_2.js file find and remove all the code that looks like this:
if('address_0' == 'address_0')
marker_0.openInfoWindowHtml(address_0.infowindowtext);
or like this:
GEvent.addListener(marker_0, 'click', function() {
dawn401382
oops now I ve really broken it!!
Hi - help what have I done wrong - the map doesnt show up at all now after removing this code
neilo
Hi Dawn,
Have you removed the map from your page?
In the div
<div id="wagmp_map_2" style="width: 515px; height: 210px;"></div>
You don't seem to be referencing your JavaScript file:
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/
</div>
dawn401382
This seems to make the problem worse
When I view the page in dreamweaver - the map placeholder is there.
If I put in the code you mention this makes it worse - still no map and the page re-shuffled itself into random blocks
Jimmy Wu
In this case, if you revert the changes you made earlier and find the line that looks like this:
icon_0.infoWindowAnchor = new GPoint(19,0);
This should prevent the info window from popping up.
rick252611
Also works in ColdFusion
I had the same problem in the map when used with Coldfusion. Removing the icon_0.infoWindowAnchor line from the wagmp_map_1.cfm file got rid of the popup.
I know it's not that relevant to this discussion, but I've been looking for this solution for a while and the search engines keep pointing to this discussion. So I thought I'd put the Coldfusion solution here.
Jimmy Wu
Thanks for the pointer. Posting solutions is always appreciated.
