'Unable to download' bug in IE when downloading from https
Thread begun 5/20/2010 9:19 am by propoint | Last modified 12/21/2010 1:39 pm by robin.harrison368334 | 5244 views | 6 replies |
propoint
After upgrading to UE 4 and updating Download behaviors on my page, none of the downloads will work in Internet Explorer over a secure connection (https). All downloads function fine in Firefox and Chrome.
The attached image shows the error message received.
I did a little searching for this error and found this MS KB article on it:
323308
From the looks of it this has to do with a bug in Internet Explorer that can be patched by updating the registry. It looks like this has to do with a Cache-Control: type header.
I can see that in the download function there is a header like this but it is not set like the kb article mentions. It might be worth making a backup of the webassist > file_manipulation > helperphp.php file first and searching it for Cache-Control:, it should be on line 690 by default. When you find this you can try to update it to be another valid value, maybe like this:
header('Cache-Control: max-age=0');
Please test it out like this to see if it resolves the issue, let us know what you experience.
After making this update
propoint
RE: UE4 Download File Manipulation not working (HTTPS)
I have tried both options. I tried the KB article fix as well as changing the line in the Helper file and I get the same results. When I open the same page on testing server that is NOT using SSL everthing works fine. I tried the fix on multiple machines running IE 7 & 8 on Windows XP SP3 and Windows 7.
I'm not sure if this is something we will be able to work around or not. If this is a bug in the browser that we cannot work around with an update to the code then it is not something that we will be able to fix. I have opened a ticket for you on this issue so that it can be checked on more. To update the ticket or check on its status login and visit your support history.
Was this ever figured out?
I have the same problem when using file download under https it can't find the pdf for download. Under normal http everything works fine?
Any help?
I found this text in the support incident:
I did some more checking and testing. In the file manipulation helperphp.php file around line 690 the header is set. I made the following changes before the line that reads the file from the system.
// set headers for download file
header("Pragma: public"); //added
header("Expires: 0"); //added
header("Cache-Control: must-revalidate, post-check=0, pre-check=0"); //added
header("Cache-Control: public"); //added
header("Content-Description: File Transfer"); //added
header('Content-Type: application/octet-stream'); //original line
header('Content-Disposition: attachment; filename="' . $fileName . '"'); //original line
header("Content-Transfer-Encoding: binary"); //added
header("Content-length: ".filesize($path)); // original line
does that work for you as well?
You ARE The Man!
That worked like a charm!
Now the file downloading works with "Https:"
Thanks very much!
Hopefully this thread will help others out there.
