You have an error in your SQL syntax; check the manual that corresponds to your MySQL
Thread begun 5/20/2010 7:08 am by Daryl | Last modified 5/21/2010 5:07 pm by Eric Mittman | 4590 views | 3 replies |
DarylBeta Tester
I have a form with two radio groups, depending on the selection that you make will depend on the next page after pressing submit.
This works perfectly in Firefox, however when I test in IE8 or IE8 compatibility mode, the page tries to reload and I get the following error...
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
My SQL is;
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../index.php");
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_logo = "-1";
if (isset($_SESSION['company'])) {
$colname_logo = (get_magic_quotes_gpc()) ? $_SESSION['company'] : addslashes($_SESSION['company']);
mysql_select_db($database_connection, $connection);
$query_logo = sprintf("SELECT id, logo FROM company WHERE id = %s", GetSQLValueString($colname_logo, "int"));
$logo = mysql_query($query_logo, $connection) or die(mysql_error());
$row_logo = mysql_fetch_assoc($logo);
$totalRows_logo = mysql_num_rows($logo);
This code works perfectly on other pages and works on this page until I press submit.
Any ideas?
It is hard to say why you are getting this error without knowing what the query is that is not valid. To print out the query that is on this page you can add in some code just after the variable that holds the query is set like this:
if(isset($_POST["Utilities_submit"]))     {
    die($query_logo);
This should let you see the query on the screen. You should be able to easily see what the issue is. If not post back with the query you get so we can check it out. Also, make sure that you look at the URL when the error occurs to make sure that it is happening on this page.
DarylBeta Tester
I got;
SELECT id, logo FROM company WHERE id = 9
Which is exactly what I would have expected.
I have removed your code and re-inserted mine, and now I get the same error again....?
Is the error occurring on this application 6 page, or on the next page that you are getting to? The query that printed out looks ok to me, have you tried running this query manually on your db to see what the result is? If you can run this query and do not get the same error then it is probably not this query that is causing the error.
It can be difficult to debug sql queries when you do not get back a meaningful error message like this. If we can find the query that is bad and print it out we should be able to quickly determine why it is not correct.
