child not populating
Thread begun 5/20/2010 6:31 am by flipout | Last modified 5/20/2010 8:54 am by Jason Byrnes | 4262 views | 7 replies |
daniel.staves407575
I can get both my dropdowns populated but as soon as I add the dynamic array the parent populates fine but the child is empty. Any ideas?
The child is linked by the parent_id
Thanks Dan
please send a link where I could see the problem.
daniel.staves407575
This post has been deleted.
your page is missing the Create Dynamic array server behavior, it seams to have been removed.
you need to add the create dynamic array server behavior before adding the populate list from array behavior.
daniel.staves407575
just confused which recordset id use, would the options be
recordset: rsCat
parent id: provider_cat_id
child id: cat_id
child text: cat_name
If so then what?? I find the docs really hard to follow I'm used to using ADDT and just trying to get to grips with your products.
daniel.staves407575
also can I change my username please I wasn't aware you was doing to use my full name?
Yes, that looks correct.
the process is:
1) create parent recordset
2) create child recordset
3) Create parent list
4) Populate with Prent recordset
5) Create child list
6) Add Create Dynamic Array server behavior using the Child recordset
7) Add Populate List from Array behavior to the onchange event of the parent list
daniel.staves407575
bingo!! thanks very much for your help. any ideas on changing my username?
Click on the Your account link on the webassist home page.
In the contact information section there is a link to Update your contact information.
You can set your forum display name here.
