Can you apply the DataAssist search wizard twice?
Thread begun 5/20/2010 2:04 am by Lee Firth | Last modified 5/20/2010 5:58 pm by Lee Firth | 2984 views | 4 replies |
Lee Firth
I need two different types of search functionality. I need to be able to search by map number and type and also by name or address or phone number. I don't think you can accomplish this with a single search DataAssist Search SB added to the page (Correct me if I'm wrong).
I have tried to add the SB twice but I get an error message which says:
Fatal error: Class 'FilterDef' not found in C:\inetpub\wwwroot\phone\numbers_Results.php on line 16
I think you can have more than one DataAssist Search server behavior on the page at once but this should not be necessary if you are searching through the same recordset. The current error you are getting looks to be a code order issue, if the class if referenced before it is defined you will get this error. This class should be referenced in the include files that should be at the top of the page. If the proper include files are above this code the error should not occur.
To set this up so you do it with a single Search Server Behavior you need to make sure that you have the form fields in place first. Then you can edit the server behavior and just add in the additional criteria. When you add them make sure to change the separator to OR, then select the column it's type, the type of comparison to make, then select the form element that this value will be coming from. This should allow you to create a single Search server behavior that does all of this.
Lee Firth
I managed to get close to what I wanted on a single search SB. Thanks Eric.
Glad to hear that, are you having any other trouble with it that you are trying to work out? Let us know if there is anything you need help with still.
Lee Firth
I'm starting to use this extension a lot and I've found that if you print the SQL that has been modified by the SB to the screen you can usually see what the problem is.
Each case would be different but if you look at this line of code:
$inv = mysql_query($query_limit_inv, $BEA_PHP) or die(mysql_error());
The query is "$query_limit_inv" so if you echo that you will see the modified SQL.
Thats my tip for the day. :)
